Can workato fast through ETL source to End ?
sashthamanik
Hi @sashthamanik
To optimize the speed of ETL processes in Workato, we need consider the following:
  1. Connector Performance: Check the performance of connectors used in your workflows. Some connectors may have specific considerations or limitations that can impact processing speed.
  2. Batch Processing: Workato allows for batch processing, which can be more efficient for handling large volumes of data.
  3. Parallel Processing: Depending on your use case, you might explore parallel processing to execute multiple tasks simultaneously.
If you explain us what exactly your use case based on that we try our best to provide solution. Hope you these points helps for the initial phase.
1 REPLY 1
Hi @sashthamanik
