Creating Collections within retry blocks
jason1
We have error handling retry logic that re-runs our recipe up to some max_attempts whenever we hit API rate limits. Since our recipe creates a Collection as part of its logic, we started seeing failures due to "table name already exists" -- which I suspect is because you can only create a single Collection for a list once in a given recipe.
Are there any good workarounds for this?
9 REPLIES 9
ben-urbanski
Hello Jason,
You could first check to see if the table already exists and drop it if necessary. Here’s a screenshot of a recipe that wants to recreate a table in each iteration of a loop (a similar problem):
ryan-stewart
Also, If you are creating a bunch of collections with retry numbers, be sure all those collections get cleaned up at some point in the recipe.
viswanathan-r
I faced the same exact issue. So I used a Ruby code which generates random 10 digit number. I appended the 10 digit to my table name. Now so far no issues.
gabriel-sim
Wow, so many clever workarounds! I'll look into it from the product side as well to see if we can provide a better way to solve it.
gabriel-sim
Hi everyone, we added an option that allows you to override the list which should address this issue. It's available as an optional field in this step.
