โ07-23-2023 05:36 PM
I have built a custom connector for my company and now I need to import that to my client's portal. I have shared a private link for my custom-build connector.
does anyone know how to import it to the client's environment?
sampath
โ07-25-2023 12:40 AM
Hi
Once you have the Custom Connector Sharing URL (private link), you can share this with your client, and they will have the option to Install the connector on their workspace once they open the link.
โ07-31-2023 09:50 PM
Thanks for the clarification. Suppose you will be using an SDK across a different Data Center; I would advise using Recipe Lifecycle Management to Export the recipe and SDK connector. It will create a manifest, which you can import to another account from a different data center.
Here's a sample of the manifest:
yesterday
@sampath wrote:Hi,
sampath
20 hours ago
Vacuum floors carefully before mopping to avoid scratches. Always wear gloves and a mask for safety during cleaning. For best results, you can also hire professional construction estimation services or cleaning experts to make your home spotless.
