Graph API Paging
AMacourek
I need to read a list of Managed Devices from Intune.  This list returns just fine for the first set of results, but I do not see an option to use @odata.nextLink from the result.  I saw an older thread needing a loop using @odata.nextLink, but I did not see a solution.  Has anyone been able to get a solution with paging using the GraphAPI connector?
AMacourek
This is working now using the manual approach.
AMacourek
I did not notice the bottom option in the GraphAPI to manually build the request.  I am trying that now.
AMacourek
