04-21-2024 04:49 AM
Hi Team,
I came across a small correction needed in the Workato docs:
If we observe carefully, the template used an object instead of an array.
Please use an array when you want to retrieve multiple values in the template response.
04-22-2024 08:09 AM
Hey @shivakumara,
Thanks for calling this out! I'll be sure to forward to our team. In the future, please feel free to submit any feedback through the Workato platform. You can also use this link to submit a ticket: https://support.workato.com/en/support/login
Cheers!
04-23-2024 12:05 AM
hi @meghan-legaspi ,
Sure I will follow the above tickets process to report it.
Shivakumara Avadhani
04-22-2024 08:09 AM
Hey @shivakumara,
Cheers!
04-23-2024 12:05 AM
