09-29-2023 09:36 AM - edited 09-29-2023 09:38 AM
is there an easier way to do this?
I have 3 companies with 5 warehouses each
so I do 3 searches t find all the costs in each warehouses and then just add the data pills together and this worked fine.
but then I started seeing the Nil can't be coerced error so some warehouses will be blank.
do I need to loop through each search and do a if .present to add them together? or is there a trick I'm missing like in SFDC where there is a way to treat NULL as 0
also, is there a way to do a loop through 3 searches? or do I need to create a list variable which I'm trying to do but can't seem to combine the 3 searches into a single list
sorry if these are basic questions very new
09-29-2023 03:25 PM
There are a lot of ways to do this, but it depends on how your data is formatted. If you can make an array of all of the costs, you can use [array].compact.sum, where compact will eliminate the nil values. Otherwise, if you want to add them up individually, you will need to handle nil values with .present? like you mentioned. Something like:
([wh1].present? ? [wh1] : 0) + ([wh2].present? ? [wh2] : 0) ... and so on
For your second question, you can loop through three searches, but first you need an input to determine how many times to loop. Here's the general idea:
Hope this helps
10-02-2023 10:13 AM
The formatting is a little hard to follow. Are you able to send screenshots?
To update the field type, you could edit the schema or just click the edit pencil and change the type using the dropdown.
Back to the formula, here are a couple examples:
Example 1: Three string variables with null values:
Formula to add:
Formula output:
Example 2: Three string variables with actual values:
Same formula as above is used.
Output of the variables (strings):
Formula output:
Be careful with spacing in the Ruby formula. If you don't have a space after the second question mark, it will error. Third row below is missing a space:
10-02-2023 10:41 AM
feel like I am soo close... here is my simple query to pull the fields for 1 company
and here is the creation of the variable and using thsoe fields:
but when I test it it seems to be putting in the right costs but within a string of the formulas as shown here
10-02-2023 11:03 AM
You are very close 🙂
You just need to click the "Formula" toggle on the upper right of the field. It's currently set to text mode.
10-02-2023 11:30 AM
ok I now have topped a "I feel stupid" moment
thank you for all your help
10-02-2023 11:36 AM
Haha, it's all good. The important thing is you got there!
