Custom attributes from ACC
pzigante
I currently am using a callable recipe Autodesk created to pull file and folder metadata from ACC and BIM360. However, it only pulls the standard metadata such as name and date uploaded etc. I would like it to get custom attributes, how could i go about this as i would need to map the attributes to the recipe, but it would require the callable recipe to be linked ot the project as the attributes may change from projetc to project.
8 REPLIES 8
david-macintosh
I think you'll need to show the data structure that is received by the triggered event in your start action to get mach advice. Show it with everything expanded if possible.
vinay
Peter Zigante as per your comments i understood that you are getting standard attributes from the callable recipe so in your case you need custom attributes for this u might need to use custom action in which u can able to give response schema as per your input requirements so the you can use in other sections
Yes, Patrick above mentioned in a DM, that i would need a GET custom attribute but it seems we cannot yet call it from ACC, i reached out to Autodesk to help me, https://forge.autodesk.com/en/docs/bim360/v1/reference/http/document-management-custom-attribute-definitions-GET/
vinay
Great Peter if you need any help do let us know we can connect
