Enhancement: Export/Print Dependency Graph and Trigger Type Indicator
mroldanvega
Hi Workato Team,
2 suggestions for new features:
1. It would be very useful if we could export the dependency graph to excel or CSV. One use case is: I want a list of all the recipes that are connected to Salesforce. I can see them in the graph, but I cannot export them (to use them as a checklist or so).
2. Another feature that would be helpful: in the dependency graph, if you can show (maybe with an icon) the type of trigger the recipe has (callable, scheuler, teams, webhook) it would be easier to identify the if a recipe is relevant or not to the search you're performing.
Tridivesh Sarangi - maybe you ca forward this to the relevant folks. Thanks!
12 REPLIES 12
I have used Neo4J for customer relation analysis / tracking but not for Workato. It's doable but would require quite a lot of effort to keep it updated with no 'live' updates coming from Workato so far. You could use it as a separate version of the truth and add your own metadata but that also has its disadvantages.
Personally I think it would be superb if you could stream a live feed from Workato to Neo4J but then again adding your own custom metadata could be overwritten.
deven-maru
Steven Marissens that's interesting. The idea to push changes to keep the graph updated may be a little tricky as there could be many interconnected dependencies.
mroldanvega
This is part of the reason I mentioned an dependency graph API, Deven Maru. Then we can update it programmatically.
